Headlight highbeam relay
Discussion in 'The Garage' started by MTBLAZER89, Feb 2, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I know you can wire this yourself, but has anybody used the Painless harness for 88-98? Just wondering if it would work with the 88-91 style headlights? If so any mods required?
    Painless Harness
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Here's a thread from way back that I had bookmarked, there's a little info in there.
    Relay Stuff
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't use tap splices to do it, I'd solder and shrink tube the connections. Just get yourself some relays at the parts store. /forums/images/graemlins/thumb.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, those 3M ScotchLock™ connectors that pierce the insulation are a BAD idea for any wire that is exposed to the elements. Water then has a place to enter the wire and wick along the conductors. Not only do you then end up with a bad connection, but the wire inside the insulation is so corroded that you can't even solder to it any longer. /forums/images/graemlins/angryfire.gif
