headlight issues
Discussion in 'The Garage' started by tecton, Aug 1, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    ok
    had a headlight go out, got another one, put it in, withint 3 hours the bulb inside popped....
    dont know what is causing this
    voltmeter reads 11v engine off...13v at idle
    anyone have a wiring diagram for the headlights?
    also, the high/low beam switch is broken
    any wirediagram for the switch, how to change it, and how much?
    thanks
    86k
    2 sealed beam lights
  2. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Maybe the new bulb was defective? Are you volt readings at the battery or the headlight socket? I would try another bulb before I spend a lot of time tracing wiring. I can't help you on the bright light switch. All of my trucks have it on the floor because I can't get my foot up to the column to turn the brights on.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well fix that first . Should be easy as undoing a plug , they show it in the common repair manuals for our era trucks , get one keep it in your garage or in your console . Then with the broken switch replaced you start looking for problems , if they don't already go away /forums/images/graemlins/k5.gif
