Headlight Plug
Discussion in 'Parts & Trucks Wanted' started by daleearnhardt01, Dec 5, 2003.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Thats right I need the plug for the leftside lowbeam on my 90 with the quad setup.
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Any auto parts store will be able to get them. I just replace all four of mine.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    or take from the nearest parts truck, you could even sneak from salvage yard easily.
    i forgot how many spades are on the back of the small rectangle headlights, is it common three, or just two ?
    also you could just use female crimp on spade connectors too from a store, in which would techniucally be better than splicing wire ends to install new plug
    good luck
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    I thought about the spade connecters but wasnt sure if that would be good enough. Its got the 2 prong connecter. Ill check Advance and Autozone.
