Headlight problems 83 FS Jimmy
Discussion in 'The Garage' started by westcoastblazin, Oct 2, 2005.
  1. westcoastblazin
    westcoastblazin Registered Member
    Oct 3, 2004
    15
    Ok, yesterday while wheeling with buddies, I ended up with a dead battery. I got a jump, and then my head lights/tail lights wouldn't work. Now, there's no melted wires, grounds are all good and hooked up. As I later noticed, I had an alternator wire melt, so I fixed that and the lights still won't work. ANY suggestions would be greatly appreciatted! Thanks! :doah:
  2. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    Always.. Always.. Always check fuses first. Then check for power/ground at the switch.
  3. westcoastblazin
    Oct 3, 2004
    15
    Well, I replaced the whole deal on the wiring, and they come on fine now. Strange that the fuse never blew, the fusable links must have done that job, but still, if they did, I shouldn' have been able to turn over the engine....
    Weird, but owell. It's all new and I placed a heat shield on the wiring near the corner of where the wires go around the block near the header onto the starter solenoid.....
    Thanks for the input Big89Burban!
    Cheers From Canada! :D
