Headlight Problems
Discussion in 'The Garage' started by Justin Fleming, Sep 13, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    767
    4
    Oxford MI
    When I turn on the headlights low beams both sides work well. when I go to high beam both light work on the driver side only and neither of the lights work on the passanger side??? :confused: :confused:
  2. dremu
    Feb 27, 2000
    15,957
    448
    East of San Francisco
    Any time I hear this kind of thing, my first reaction is "grounds."
    Go check that the ground on both sides actually connects to the body; also check that the connectors for the bulbs are clean and not corroded. I had to replace a socket on my '85 'cuz the wiper was freakin blue from crap :(
    -- A
  3. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    I wouldnt think that it would be a ground issue if the lights on that side work while the low beams are on??
  4. Kiwi John
    Kiwi John 1/2 ton status
    Jun 24, 2005
    249
    West Sussex, England, U.K.
    First: Swap the bulbs from right to left and see if the problem is the same. That proves the bulbs.
    Then check fuses. Are the L & R Hi beams on seperate fuses?
    Then do what dremu said. dodgy earth connections cause all sorts of wierd effects.
    then, if problem is still there, you will have to start tracing wiring to relays switches etc.
  5. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    Does anyone have a diagram that they could attach of the lighting circuit for an 86 k5 blazer
    thanks
  6. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
