Headlight/Radio/Electric Problem.
Discussion in 'The Garage' started by chevydan3, Feb 8, 2006.
  1. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
    Alright guys. When I hit the headlight switch to turn on the headlights, my radio dies and loses all the memory stations, time, settings etc. Then when I am driving, sometimes my stereo just dies and my headlights flicker. Driving home tonight, my headlights/radio completely shut off twice for about 20 seconds. Now the common factor here is that both the headlights, and the 12v constant for the radio, are drawing power from the constant hot, not the switched hot. So what is the deal, my connections look good at the starter, junction block and under the dash. I found a link to a wiring diagram when I searched on this subject and it says the the cig lighter is connected to the hot for the headlights, could my cig lighter be causing all of this. Am I drawing too much power, do I need a thicker wire to the fuse box, or does this sound like a connections problem? This is driving me nuts.
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Cig lighters do cause problems. I replaced my lighter early on. Don't recall anymore what weird thing it was causing. It's a cheap fix, so might as well, and check the wiring to it. Also check your grounds all around.
  3. chevydan3
    Nov 27, 2004
    409
    Reno, Nevada
    I pretty much narrowed it down to the headlight switch, so I will change that and see what happens.
  4. Skigirl
    Apr 2, 2001
    2,563
    Yea, I've changed that out too.
