Headlight Switch Replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigTex, Feb 24, 2002.
  1. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    I just replaced my headlight switch and now when I turn my headlights on, the green flasher arrows and the little blue high beam indicator lights turn on. When I click my high beams, the blue indicators turn off. My blinkers work fine and all on the outside, but when they flash my gauge lights also flash! Has anyone ever had this problem? Could the new switch be defective?
    What could this be?!!!!!
    <font color=red>"PROCRASTINATE NOW!!!"</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
  2. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    It could be defective.... but i think you got the wrong one. There are several types of that switch for the several different years of our trucks. Put your old one back in and see if it still operates the way it used to.
    1990 K5 4" lift, 33" MTR's, 14FF w/ Detroit locker, D44 w/ posi, 4.10's Raptor Tranny and Velvet Rides !
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I'm having a similar problem w/ my headlight switch. When I turn my headlights on, my high beam indictor comes on, my gauge lights goes out, and my fuel gauge quits working. This is the old headlight switch, which I am sure is bad. It sounds like you have a defective switch, but I suppose you could the wrong one.
    1-800-MARINES When it absolutely, positively has to be destroyed overnight!!!!
  4. BigTex
    Dec 27, 2000
    974
    South Texas
    Yeah, that sounds like what mine is doing. I guess I'll try the old switch again.
    Thanks for the advice Tori..
  5. BigTex
    Dec 27, 2000
    974
    South Texas
    TTT
  6. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Anyone have a napa, checker or autozone part number for a headlight switch out of a 1979 K5
  7. LlanoK5
    LlanoK5 1/2 ton status
    May 26, 2002
    202
    Llano, Tx
    When I bought my 83 my fuel gauge would quit working the right turn signal indicator would light up and stay on and most of the dash lights would not work. I replaced my headlight switch to no avail. I finally took the time to pull out insturment cluster and found a burned trace on my printed circuit panel. I bought one a wrecking yard for $15 put it in, but still had the same problem. I finally got out the trusty old test light and found a blown fuse. Since I replaced all that I haven't had problem with any of it. And all my dash lights work properly.
