Headlight Switch -> Toggle Switch Conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xdelirious45x, Jun 18, 2004.
  1. xdelirious45x
    xdelirious45x Registered Member
    Apr 9, 2004
    71
    Lyndhurst, NJ
    Is it possible to convert your headlight switch to a toggle switch. I have a 1988 Chevy Blazer. I have the 4 headlights total. I want to hook up the top headlights to a toggle switch and the bottom ones to a toggle switch. The reason being, I think it will be easier to turn one or the other on if not both, and I think it will be easier if there is a wiring problem. Would I be able to just transfer the power and ground wires from the headlight switch now?
    I asked a friend and he said I could, but when I turn on high beams, the bottom lights come on so will I be able to just disconnect the wires?
  2. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    I'm not trying to be facetious or a wise a$$, but you can do whatever you want. Anything is possible if you have the know how, money and or time. You just need to have the correct wiring kit or the know how on how to hook it up yourself correctly using your own "kit."
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look closely at the plug on the back of the top headlights. See those THREE wires? /forums/images/graemlins/blush.gif The top set of lamps contain a dual filament bulb. One focused for low beam and the other focused for high beam. Switching to high beam changes which filament is on in the top lamps, and also turns on the lower lamps. /forums/images/graemlins/thumb.gif
    I'd leave it like it is. /forums/images/graemlins/cool.gif
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    here is a quick and dirty diagram for you. this will also make your headlights brighter most likely as it will cut voltage loss if you keep the relays close to the headlights.
