headlights freaking me out !!!
Discussion in 'The Garage' started by scrappyk5, Apr 28, 2005.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    when i am driving with my headlights on at night , all is well. when
    i go to use my high-beams , the headlights and the high-beams start to flicker and go out. now if i go back to using just the low-beams , all is
    fine . :confused:
    do i have a relay going bad or something going bad ?
    if so , what is it ?
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Sound like a bad ground for your high beams
  3. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    What year??
    Could be bad grounds--or the headlight switch,it has a curcuit breaker built into it,instead of a fuse--it will turn on and off if there is a short in the headlight wires,or too much load on it--I sold lots of headlight switches for fire trucks and police cars,the added load of all the extra lamps they used pushed the switches to the limit,and the breaker would cause the lights to flick on and off...do you have off road lights or other non stock lamps added on to your truck??--if so,you may need to wire them to a separate relay and switch..
    If your truck is a newer one,it might have a headlight relay for the high beams-(which could be faulty and cause the same symptoms)-I'm not too familiar with 90's and up trucks,I know the newer ones have the lights on constantly whenever the motor is running,they must go thru more switches and relays(if used?) than a "regular" one you turn on manually at night...I think the dimmer switch could be responsible too,might look into that--nothing worse than losing the headlights on a dark road with no streetlamps! :yikes: :crazy:
  4. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I've seen the dimmer switch do that on a 78' Caddie before...
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    492
    Grand Rapids area
    I've seen the foot dimmer switches do that. Kinda scary to have the lights turn off in the country at night.
  6. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    this was the casue in my 72 blazer. :confused:
