headlights quit - is there a headlight relay?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Apr 24, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I know that's probably a dumb question, but I don't know. I can see what appears to be my hazard relay and my turn signal relay, but it looks like there is a third relay or box or something on the fuse box.
    The markings on my box are somewhat faded and hard to ead.
    The fuse box is from something like a 77-79 k10 (it has bus fuses not glass fuses.)
    Can anyone think of another reason my dealights would not work? They were working fine until I took the truck and and beat the snot out of it.
    My brake lights work, my turn and hazard lights come on when I turn on the headlights, but the headlights themselves are dark.
    I tried jiggling both headlight sockets, but it didn;t do anything. Both headlights are a few months old and I just can't believe they boith went dead at the same time no matter how hard I beat on the old truck.
    -- Mike
  2. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    pull the headlight socket and check for electricity with your multimeter, or check continuity on your headlights
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    The headlight switch has a built-in relay (?) or something to that effect. Anyway, you have to replace the switch, as there is no way of resetting it.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    could be contamination on the contacts in the switch.
    pull it and rip it open, clean the contacts and apply silicon dielectric grease.
    to disassemble you have to bend a couple tabs.
    could be wrong mine has old glass fuse wiring
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Check your high beam switch on the floor, thats happened to me in the past. Sounds exactly like it.
  6. johnnyK5
    johnnyK5 Registered Member
    Oct 5, 2001
    95
    Washington, PA
    I agree. My highbeam switch puked with the same symptoms.
