headlights quit working!???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stevewix, Feb 20, 2005.
  1. stevewix
    stevewix Registered Member
    Dec 2, 2004
    83
    my headlights quit working last night at the bar, everything else works, even the turn/brake/tail/4-way/marker lights. no bad fuses in the block under the dash, and interestingly enough, they come to life when i pull back on the high-beam switch on the column and hold. the hi beam switch doesn't make a prominent click, although i never paid attention to it's sound and feel before, it feels like nothing is happening. no notification of hi-beams or anything. as far as i can tell, there are no other fuses, relays or loose grounds.
    any ideas greatly appreciated. i'm confident it's either the headlight switch on the dash, or the dimmer switch on the tree.
  2. red77blazer
    red77blazer Registered Member
    Feb 13, 2005
    47
    Washington
    technician a says
    hi/lo beam switch
    by the way what year?
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Had a similar problem on my 79. I replaced the high/low beam switch and all was well.
  4. stevewix
    Dec 2, 2004
    83
    cool, that's what i was thinking. stomper it's an 85 m1009.
