Headlights stuck on bright
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SkulzNBonz, Jul 28, 2003.
  1. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Went wheelin' this last weekend, used the bright lights (night wheelin' /forums/images/graemlins/thumb.gif), now the darn lights are stuck on bright. It's an '86 w/ tilt column. I'm sure I'm not the only one that has had this happen, but from my search efforts, I for the life of me couldn't find another post about it. So what did you do to remedy the problem? I've had the dimmer switch stick before, but never stay stuck. Thanks all.
    John
  2. dyeager535
    26,982
    191
    Probably the switch is out of adjustent. You can see the rod running down to it (I think) if you look under the dash. Two screws allow you to adjust it. May be easier to drop the column. (two 15MM nuts, plus assorted trim pieces IIRC)
  3. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Thanks D., I'll jump under there and check it out.
    John
