Headliner
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Madbomber88, Mar 20, 2005.
  1. Madbomber88
    Madbomber88 1/2 ton status
    Feb 7, 2001
    185
    Mass
    Is there any other place besides LMC to get a new headliner for my 91 K5?
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    You can do it yourself, its pretty easy. This is asuming the hard backing is still good. Just take the material off and then scrape all the foam stuff off. Spray your glue down and apply the new material. Easy job :grin:
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Yeah what he said. I found the material at a fabric store. Had the color I wanted and even had the foam stuff attached to it. Cost me like 20 bucks for everything to do my own.
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I just did the headliner in my 88. easy to do. I got the material from JC Whitney. Pepboys used to carry it.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Material is cheap and easy to deal with. Get material and spray adhesive and do it yourself. A little camo maybe -
  6. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
  7. Silverado_K5
    Silverado_K5 1/2 ton status
    Jun 4, 2003
    707
    Weston, Oregon
    opfor2,
    You can use 3m general spray adhesive, or I picked up a can of Heads Up that works the same, but half the price. When you spray the adhesive, let it set or about 30 seconds to a minute or it will be really wet and can saturate through the headliner.
  8. Madbomber88
    Feb 7, 2001
    185
    Mass
    And you reuse the carboard backing?
  9. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I've done 3 headliners. I reuse the cardboard. Just gotta get all the old material and glue off. I used a small wire wheel in my drill. Just gotta be carful not to burn through.
  10. cbbr
    Jul 17, 2004
    14,681
    This thread says is a pertty good overview. I re-used the cardboard, but worked on the "top" by flipping it over before recovering so I would not have to scrape the crap off and so that the adhesive would have a clean surface.
    I used 3M spray adhesive that I got at the fabric store (I think Super 77) to hold the fabric to the pad.
    I also wanted better insulation, so i used a padded packing blanket from Harbor Frieght instead of foam. The 3m orange foaming spray adhesive (I forgot the name, but "super 66" maybe) holds it up easily. Sounds a little heavy, but it has held up well in the La. humidity/heat. The packing blanket was about $5.
    http://coloradok5.com/forums/showthread.php?t=130584&highlight=headliner
