headliner
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazingboy, Aug 11, 2002.
  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    Hey guys my headliner is starting to fall on the passesnger side on a k5 are they glued in like a regular car or can you take off the trim and tuck it in behind it. It is a 87.
  2. diezel11
    diezel11 Registered Member
    Oct 2, 2001
    10
    New England
    mine was the same way i took it out roof is same color as truck
  3. dyeager535
    26,982
    191
    Glued in like regular GM car. (foam covered headliner material glued to usually cardboard backing)
    You can pull it out as has been mentioned, but if you HAVE to have it in place, the only right way to fix it is to buy headliner material (foam on it) scrape the backboard, and glue it back in. Fairly hard to do correctly from what I've witnessed. By "right way" I mean the way that will look "stock".
