Heads, Motor or Gasket.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CTBlaz45, Jul 29, 2003.
  1. CTBlaz45
    CTBlaz45 Registered Member
    May 16, 2003
    50
    Killingworth CT
    My Blazer is spewing coolant out of the overflow bottle. I theink it is being caused by a bad head or head gasket. If it is the head I think I will just replace the motor with hopefully a crate motor. If I can afford one. I am looking for crate moter sugestions basicly stockish for an 89 Tbi 350 but maybe better then plain stock. As the cooling sytem overflows into the bottle it is being replaced by air. So i feel it is a head problem. /forums/images/graemlins/k5.gif
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    My 6.2 did the same thing, it had a broken head bolt.
  3. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    Thst would not be too bad bolts are cheap.
  4. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    You have to figure out which side is causing it.
  5. BigBadJap
    BigBadJap Registered Member
    May 23, 2003
    76
    Alberta, Canada
    I had a nissan truck that did that EXACT thing. Dealership told me it was a toasted headgasket; so I replaced it for $600 , and it didn't fix the problem.
    The problem turned out to be a bad $8 thermostat; man was I pissed.
    I'd start with the thermostat, it's cheap and easy to replace. Also, keep an eye on your water pump. If you run low/out of coolant, it doesn't take long for the water pump to burn up.
    Good luck.
  6. CTBlaz45
    May 16, 2003
    50
    Killingworth CT
    I did replace the thermestat did not help
  7. BigBadJap
    May 23, 2003
    76
    Alberta, Canada
    Do you think it could be something like a plugged coolant passage, bad water pump.
    Might be best to take it to a shop and eliminate the guess work.
