Heads ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Sep 2, 2001.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Another post reminded me about this set of heads I have. 886 is cast into the heads. I thought I heard something about them being good heads one time but I can't remember. There SBC heads. thank you
  2. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Nobody can help me out with these heads? Anything helps.
  3. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    If you give the casting number, I may be able to help!
    Bo
    If it breaks, it wasn't good enough!
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Sorry Im a Pontiac guy. I could tell you which heads are goor and which are bad for Pontiacs.I belive though that they are a decent set of heads. They flow pretty decent for a factory iron head. I know though that my buddy runs them on his 66 Chevelle. He brack races it, and it runs mid 13s.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I dont remember the casting number of hand. I'm in CO and the heads are at home in AZ the only thing I remember is that 886 is cast into them, and one time I thought i heard that these heads were on of the best flowing cast iron heads GM put out. I think that they are from the mid to late 60's, the blocks they came with were. I do remember a 6 digit number that was cast into it. I remember 33_886 I think. thanks
  6. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Any head from the late 60s flow great. Just stay away from heads made during the mid 70s and early 80s. During all the smog bs the choked the heads way down, and took all the power away.
  7. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    are you sure that casting wasnt 333882, i coulndt find anything for 886
    Check out my 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a>
  8. Liberator
    Jul 16, 2001
    276
    I couldn't find anything for "886" either!
    Bo
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I'm almost 100% on the number 886 being cast in the the head between the middle two cylinders near the valve springs. I may be wrong though. What can you tell me about the 882 heads? thanks
  10. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    Well, the 882's have 76cc chambers, 1.94 intake valves and 1.50 exhaust valves. Im pretty sure they are good heads from the standpoint that they are better than some later castings made durring the 70's and 80's that were more smog oriented and not as durable. Vortec heads are the best prodiution cast iron heads you can get
    Check out my 73 K5 &lt;a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm&gt;http://www.geocities.com/xk5blazerx/73k5.htm&lt;/a&gt;
