Heads???
Discussion in 'The Garage' started by Confedneck, May 14, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Ok guys, bought an 010 4 bolt 350 today, its already .03 over with one sleeved cylinder.... are vortec heads compatible with this motor, i believe it was used 69-75...do i need more info off the block stamping or??
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    They'll fit but give us more on the 'big picture'
  3. Confedneck
    Nov 1, 2002
    5,236
    the big picture is to have a 450-500 hp small block for my 86 on pump gas...
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    YA! /forums/images/graemlins/thumb.gif
    Vortecs and a supercharger! /forums/images/graemlins/thumb.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    To make that much power you're going to need a cam with way more lift than the Vortec heads can handle without modifications. /forums/images/graemlins/frown.gif They probably won't even flow well enough to support that power range, regardless of cam lift. To make that kind of power you're going to have to step up to the plate and buy some good aftermarket heads. /forums/images/graemlins/eek.gif 450-500 HP is asking a lot from a 350.
  6. Confedneck
    Nov 1, 2002
    5,236
    jegs has some relatively inexpensive aluminum heads out, but arent cast heads stronger and less prone to warpage?
  7. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Wow...I agree, Vortec's arent going to cut it. AFR's, Brodix or Trick Flows. If your serious about this buildup I would suggest you also post this question on the Team Chevelle board under the "Performance" area.
    http://www.chevelles.com/cgi-bin/forum/ultimatebb.cgi
    Theres several people there with these kind of motors who are more than willing to provide info /forums/images/graemlins/thumb.gif.
  8. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I use to be on that board all the time a few yers ago when I had my chevelle. Great bunch of guys or at least use to be
  9. 88Silverado
    Mar 13, 2003
    2,664
