Heard you had something to fix my axle problem
Discussion in 'OffRoad Design' started by desertrat67, Jun 13, 2006.
  1. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Mr Watson, The two holes were the studs go on my D60 front have stripped out(the ones in the housing). I have heard you have a fix for this and was wondering what it was. IF you don't and I heard this eroneously then just tell me to bug off. Thanks,
    ryan
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    Get you some heli coils or you could possibly drill and tap it larger ....
    Ie , No ORD does not make a fix for that .
  3. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    someone in another forum said stephen had somthing for this, the only reason i asked. thanks.
  4. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I just had to heli coil the front hole...did the rear one 6, 7 months ago....
  5. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    If ORD can't set you up then PM me and I can. You will need to have a couple things go your way for a step-stud repair:
    1. The existing factory holes need to be positioned in the center section so that there's enough material to tap a 3/4-10 hole 1" deep. I have seen diffs where there was plenty of room for a step-stud and others the tap would break out the side.
    2. You need to have the ability to tap a 3/4-10 hole ...ie...drill,tap,drill press and a small amount of machining ability.
    3. You need to know how thick your front spring pack is and if your going to use a Zero rate to determine overall stud length.
    Sorry for the high-jack on the ORD sub-page but desertrat67 has been trying to cure this problem for awhile now and I have fixed some locally like this.
    Jeff
  6. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    thanks for the reply. I will be getting a hold of you as soon as I get my burb home and can measure the spring pack thickness. i will also have a look at the housing to see if it is thin in that area or not.
