Heat riser valve thingie...
Discussion in 'The Garage' started by jhellwig, Mar 7, 2006.
  1. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    That little valve in the passenger side manafold.
    Does it take vaccume to open or close? I have no vaccume line running to it right now.
    My intake manafold is getting very hot very quickly under the carb and cooks the fuel out of the thing so that warm starts are very hard to do. It is an edelbrock intake and carb.
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,074
    486
    Grand Rapids area
    Yes, it should be open except during warm up. I ditched mine when I went to headers, but I remember that it ties into a thermal ported vacuum source. It's really only an advantage if you are also using the THERMAC unit on the air cleaner. It gives you warm intake air during warm ups in cold weather.
    If you can't get it to work right, just wire the thing open. You'll be wasting gas and losing power.
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    The previous owner of my rig just tack welded the darn thing open.....haha!
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    IMO the heat riser is not your problem.
  5. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    X2
    I belive it take vacuum to close it
    and not to open it.
  6. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    I disagree. A heat riser that is stuck in the closed position could definitely cause his problem.
    That being said, I believe chevy designed them to fail in the open position.....but I am not really sure on that. It is possible that it is stuck closed, just not probable.
  7. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    you might want to invest in acarb spacer that is not metal to keep the carb alittle cooler. search Jegs and Summit for one that will fit your carb/intake.
  8. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    fail safe!..
    Its hooked up so its only closed when vacuum is applied to it when its cold..there is an internal spring that holds it in the open position when no vacuum is present..so if its disconnected ,it will be open..
    I found my 305 runs much better with the heat riser closed during my usual 5-10 mile runs to do errands in the winter's cold..it warms up faster,gets better MPG,and I swear the heater even works better!..when I'm planning on going on a longer trip,I remove and plug off the vacuum hose..
    I've been too busy to hunt down another thermal vacuum switch (its the one in the t-stat housing that controls the EFE valve/heat riser)..but plan to soon..
    My edelbrock is a cold blodded S.O.B. on cool damp days with rain..it will frost up and stall every time you try to idle it,and is dangerous in traffic!..I found leaving the EFE "closed" helps a great deal in that situation..I suppose everyone in CA and AZ is now wondering "WTF is a heat riser?"...:p:
  9. jhellwig
    May 7, 2005
    420
    Bonaparte, Ia
    Cool. Thanks.
    I was mostly checking just to make sure that I wasn't burning the crap out of something that I could have avoided buy just some cheap vaccume line.
  10. 1-ton
    Apr 17, 2004
    2,882
    160
    Las Vegas, Nevada
    Vehicles in the west coast come with EFE valves as well, but they are not needed unless you live up North. The California smog Nazi's actually inspect for EFE valves as part of there visual inspection. Hell, they even require you have the little dash pot, and 12 Volt activated vacuum solonoid, which kicks the carbureter throttle lever up higher, when you turn on your air conditioning.
