Heat riser?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, Jan 10, 2001.
  1. dyeager535
    26,982
    191
    Anyone that knows what this is (little valve on passenger side, bolts between exhaust manifold and exhaust pipe) have any tricks to remove it? I will be keeping the manifolds, and have already bent the tabs on it so that it is wide open all the time, but I'd rather just replace it. I was wondering if any company actually makes a piece that fits in there but does not have the valve? I know I could pull it back out, cut the valve out, then plug the hole on the side, but I'd rather use a solid piece for a no worries seal. BTW, I already have dual exhaust, and I am going to be going to Vortec heads, so there is no heat crossover cast into them, so with it operational, I would be forcing that bank of cylinders to ingest almost all of its own exhaust...not a good thing I'm sure.
    Dorian
    My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Take your K5 to an Exhuast shop and they should be able to remove it and lengthen you exhaust pipe to fit up..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  3. dyeager535
    26,982
    191
    Thanks for the suggestion, but its not possible, because the mounting flange, unlike the drivers side, is flat. That piece is required so that you can use a flat gasket, then the exhaust pipe mates up to that piece, which has the tapered flange cast into it. My friends started to rattle after he wired it open, I'm just trying to prevent that, and since I have the exhaust already unbolted on that side, figured I better check and see if there are any "adapters" out there for that.
    Dorian
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Mine is loose also. We took a set of manifolds that had that riser on it and removed the riser and then had the exhaust shop make flanges for it.
    Have you tried taking it to a shop and see what they say?
    Mike [​IMG]
  5. dyeager535
    26,982
    191
    Nah, haven't tried that yet. The truck hasn't been inspected yet (no VIN, no plates!) so I don't know what year they are going to call it. If they call it older than about 1980, I can probably get a shop to make something like that. Unfortunately, around here, MOST shops won't even touch a vehicle that you want dual exhaust on. The fines are too much, and I guess it's not worth the risk for them. Plus I like doing stuff myself, the one thing I can't do is bend pipe. Not that I would necessarily have to, but unless its run by someone I know and trust, I wouldn't even let them put their hands on my vehicles.
    Dorian
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    10-4 I know how ya feel....
    One thing you can do is maybe take the riser off and just take that to the exhaust shope and ask if they can make some sort of open spacer to fit in its place..
    Or you could take the riser off, and remove the butterfly completely. Then weld the hole closed(inside and out) where the rod for the butterfly came through and then re-install it.
    HTH
    Mike [​IMG]
  7. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Most corvette catalogs carry a heat riser spacer for 2 inch manifolds. 57-65 corvettes with fuel injection use these. Think they are around 20-25 dollars. On my 69 corvette I just made the heat riser stick open.
  8. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    Wire, or better yet, weld the thing open.
  9. scavenger
    scavenger 1/2 ton status
    Mar 31, 2000
    111
    Southern Wisconsin
    I would like to know how you can tell if the heat riser valve is open. On my 85 the the rod that opens and closes the valve was removed before I bought the truck and and I suspect there may be some restriction because the valve may not be all the way open. The prong that the rod attaches to is frozen in the 9 o'clock position facing the firewal. Any Ideas...thanksl
  10. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Why not just get a set of headers? You can find good sets from about $100. You'll gain some horsepower in the process too. I'm sure you'll also be able to find headers that are street legal.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  11. dyeager535
    26,982
    191
    Great idea, thanks! My dad has a '68 Vette, and of course the catalogs, so I opened one up, sure enough, 2" spacer, 64-74 vettes, $20! Thanks!!
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
  12. dyeager535
    26,982
    191
    Too much hassle. The trucks have plenty of room, thats for sure. But DECENT headers (as in will last as long as manifolds) like Stainless or Ceramic coated, will cost you a minimum of $300. Then you have to have the exhaust modified. I already have factory true duals, in very good shape. Since this isn't a super high revving truck, the header benefit will be less noticed. I don't disagree, headers make a big difference though...I've actually almost been converted over to them...just not quite yet : )
    Dorian
  13. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    Dorian,
    What supplier are you looking at for the spacer? My frien'ds van (75 Chevy) is having problems with the heat riser as well, and $20 bucks sounds like a cheap fix. Thanks!
    It's not what you buy, it's what you build!
  14. dyeager535
    26,982
    191
    http://www.riksvet.com/ thats the catalog that has both the 2" and 2.5" "spacers" as they call them. The 2" was $18 something. HTH
    Dorian
