Heat Shield needed near gas tank when re-routing exhaust?
Discussion in 'The Garage' started by The Butcher, Aug 22, 2005.
  1. The Butcher
    The Butcher 1/2 ton status Premium Member
    May 17, 2005
    419
    39
    Texas. In a van, down by the river!
    I just raised the bumpers on my '91 K5 with a 3" body lift. Now that they are raised I am ready to put on the dual exhaust. Going to be running dual Dynomax 2.5" inlet/outlet mufflers and put the exhaust out each side behind each rear tire. Now that the bumpers are moved up I want to raise the exhaust as well to cover up the now exposed rear spring hangers, and also to tuck the exhaust closer to the body.
    Do you guys think I will need a heat shield around the pipe where it goes between the spring hangers and gas tank? As it sits currently, the pipe is 6" or so away from the gas tank, but if I tuck it between the two it will be only a few inches from the gas tank. I was thinking of using this as a heat shield:
    http://www.jcwhitney.com/autoparts/...006315/N-200005084+111+1990+600012697/c-10614
    Anyone have any suggestions as to whether that is needed and if it is a good idea? If I run the exhaust out the passenger side as well, what are the things I need to be concerned with as far as keeping the exhaust away from fuel lines, etc.? Thanks for your help.
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    You get alot of rain there in Texas? That was funny. Laugh damnit!! I'm thinkin that you could prolly get away with wrappin it with asbestos or whatever is the new fangled deal.
  3. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    My exhaust is about 3 inches from the tank and never been a problem. It was like that when I bought it years ago.
  4. The Butcher
    May 17, 2005
    419
    39
    I'm not really following you on that one. :confused:
  5. The Butcher
    May 17, 2005
    419
    39
    My truck is at the shop right now, so I could be off in my guesstimate on how far away the pipe is or will be from the tank. Is your pipe in the factory location, or was it moved for a custom exhaust? If it is in the factory position, then that is where mine would be. Moving it up between the spring hangers and tank would make it pretty close to the tank. Not sure if it is close enough to warrant concern, but it seems like a fairly bad place to put something REALLY hot.
  6. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    It's in the factory spot, 3" single exhaust. Do you have the factory skid plate under the fuel tank? You could just attach a piece of sheet metal to that to wall off the side of the tank where the exhaust comes close.
  7. The Butcher
    May 17, 2005
    419
    39
    I do have the fuel tank skid plate, so that is pretty much what I was thinking about doing if I didn't use the tubing from JCWhitney. How thick of a piece of sheet metal would be sufficient for that kind of thing? I assume that the metal helps dissapate the heat much like a heat sink or cooling fin instead of actually shielding the area like an insulator. Are my assumptions correct about that?
  8. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    What is the shortest distance from the factory exhaust to the tank? I've been running a custom duals for many years with no problems. I did not realize just how close the exhaust is to the tank untill recently... 3in
  9. dyeager535
    26,977
    Feel your exhaust after the truck has been running for awhile. I suspect you'll see that it's warm, but not hot enough to pose a hazard.
  10. The Butcher
    May 17, 2005
    419
    39
    Thanks for the responses guys. The factory exhaust is obviously at an acceptable distance from the tank. My concern is that re-routing the exhaust to tuck it up under the body better now that I have a 3" bodylift will make it run too close to the tank. Once it has been re-routed it could be as close as 1" from the side of the gas tank. I'm just concerned that might be an issue. Do you guys think that it might not be that hot by the time it gets to the end of the tubes, thus a heat shield might not be needed?
    Thanks.
  11. dyeager535
    26,977
    Well, it's not like you can't see how hot the pipes get and make the determination yourself, right? I dunno what the ignition temp is for gas vapor, but I suspect the exhaust back that far won't be hot enough.
    The thing to worry about is sparks. If the pipe rubs the tank or anything else, THAT would be cause for concern. Mount the exhaust solidly, not the cheapy plumbers strapping I see often.
  12. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    My exhaust runs within 2" of the tank. Its not my favorite set-up, and I'll probably change it in the future, but for now that's where it is and it hasn't caused any problems (been that way for 1 1/2 years).
    I did fab a heat shield for the fuel filter on the frame rail. The exhaust is about 4" from that. Again, I haven't had any problems, it just seemed like if there would be an issue, that's where it would be so I fixed it.
  13. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    My pipes are less than an inch from my tank.They dont realy get that hot.
  14. The Butcher
    May 17, 2005
    419
    39
    Thanks for the pic. That's exactly where I am thinking about putting the pipes. Then I'm going to turn them at a 90 degree angle just after the rear spring hanger to dump each side straight out. If I catch on fire, it's your fault! :D
    It sure was nice of you to turn your truck over so I could get a better look at the pipes. :laugh:
    Thanks for the input guys.
    Butcher
