heat shields for mufflers
Discussion in 'The Garage' started by 69K5, Jun 16, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    subject says it. I have decided to bedliner the inside and outside of my blazer. But my flowmasters get the floor hot as /forums/images/graemlins/angryfire.gif. i was worried about it messing up the liner. I could bake cookies under my driver seat easily .so what kind of heat shield can i put over them or somewhere. I can get header wrap for the headers but what about the mufflers?
    thanks /forums/images/graemlins/grin.gif
    Nathan
    69K5 /forums/images/graemlins/k5.gif
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Which way are the oval portion of the muffler's? Up/down, or side to side?
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    side to side if i understand that right.
    like this under the floorboard both sides of the t case and the pipes turn out in front of the rear tires
    000000000
    00000000000
    000000000
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I used some sheet metal, make them a little bigger than the width of the muffler. Attach them to the floorpan, or frame, leaving about a 1" airgap between the sheetmetal/muffler, and the same 1" airgap, between the floorpan/sheetmetal.
    Make's alot of difference in transffered heat to the cab/box area. /forums/images/graemlins/grin.gif
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    cool thanks. /forums/images/graemlins/grin.gif ill give it a try
    nathan
    69K5
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yeah just bend up some sheet metal, it's works and it's cheap... /forums/images/graemlins/smile.gif
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Or just wrap the muffler with the header wrap...
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thought about that but wasnt sure how much it would help. i know it helps keep it down a little, i also wasnt sure how long it would last on the underside of the trruck
    nathan
