Heat soak starter
Discussion in 'The Garage' started by 84mudmachine, Sep 22, 2004.
  1. 84mudmachine
    84mudmachine 1/2 ton status
    Dec 23, 2003
    184
    Kansas
    I have been having a heat soak issue with my starter. I ordered a ThermoTec heat shield from Summit, and I would like to know if anyone else has used this. /forums/images/graemlins/ears.gif
  2. sean'schevy
    sean'schevy 1/2 ton status
    Aug 5, 2004
    149
    New Egypt, NJ
    WOW good timing just had this problem today i have a set of hooker header on my big block and a power masters mini starter witch seems to help not as close to headers. but i really dont want to mess this starter up cost alot and had nothing but prob withs other starters ive used. and yes i even put a brand new flyweel in. Im thinking header wrap shield a good idea too they make those for mini starters.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    have either of tried putting a remote solenoid on it?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I used to have a blanket on mine a long time ago but I lost it and I haven't had a heat soaked starter in a long time. Fortunately running #2 cables eliminated this problem.
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    If your cables fixed it, then you were getting heat soak and too much resistence in your battery cables, not the starter selenoid.
  6. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    I put a remote on a few months ago, but it didn't help at all. If this cover doesn't help, I will try the #2 cable. /forums/images/graemlins/peace.gif
  7. 84mudmachine
    Dec 23, 2003
    184
    Kansas
    I put on the wrap, but it seems to still have some problems. I think maybe the starter is old and not in very good shape. The wrap does work well, the wrap itself stays nice and cool. What do you guys think?
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't know what fixed it to be honest with you. I bought the cables two years after the last instance of heat soak.
  9. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
  10. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I tried using the blanket, but the starter must've already suffered some heat soak damage, therefore the blanket didn't help. I run a 489 bbc with headers, and for me, I solved the problem with a new hi torque mini starter, which I wrapped up in the blanket. No heat problems now!
  11. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've had that problem on all of my K5s and a remote solonoid fixed it in every case. I used the Summit kit. /forums/images/graemlins/thumb.gif
