Heated O2 sensor install
Discussion in 'The Garage' started by sled_dog, Apr 8, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Should I put an inline fuse on the power wire for the heater? If so what size do you guys think? Also what about installing a 4 wire sensor? I was reading and it only seems to be better than the 3 wire(has another ground for the signal wire so it has less interference). Has anyone run a 4 wire? Thinking I may be the first to test it out.
  2. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Sled dog,
    you got most the same questions i do. Im going with the wiring harness from AFI. Should be here in two weeks. Id imagine you should put a fuse in there. It cant hurt anything. Im also going with the 3wire, because im running headers. Other than that, im no help.
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    I would think you'd want to run a fuse a few steps down from the gauge of the wire.
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I put a 3wire heated o2 sensor in my 71.I've switched to TPI so that's why I have a o2 sensor.
    Here's a link to the pic's when I installed it.Captions to each pic. are under the pic.
    Click HERE
