Heated O2 Sensor
Discussion in 'The Garage' started by 91GMCSuburban, Jan 14, 2005.
  1. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    How do I hook one up if I have a single wired O2?
  2. dyeager535
    26,982
    191
    I think there is just another ignition wire that needs hooked up, and PERHAPS a ground wire.
    Why are you installing a heated one? Are you experiencing problems with the one you have now based on it cooling off at idle? (Even the GM manual says this can be normal though)
  3. 91GMCSuburban
    Dec 9, 2002
    318
    San Antonio, TX
    rebuilding the engine with headers and heard there is a problem with keeping the O2 sensor at the right temp.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I bought one for headers, but haven't installed them yet. You are supposed to hook up the extra two wires to a 12V switched wire and a ground.
  5. dyeager535
    26,982
    191
    Get headers with the O2 bung if you can, if not, weld it in right after all 4 tubes join.
    I'm not running a heated one on mine, and have no problems with closed loop. Run what you have, THEN if there is a problem, go with the heated, unless you have to replace the one you have now and the price difference is justifiable.
  6. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    I agree, definetaly try what you have first. I had bought one for my iroc when i put headers on it, tried the old one first, never had a problem, returned the heated one and saved me some moneys
  7. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    cfm technologies... the tbi specialists did a write up on this on their website,,,
    cam
