Heated O2 Sensor?
Discussion in 'The Garage' started by Hossbaby50, Feb 24, 2005.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Where is the best place to get a heated O2 sensor for a good price. Anyone have a part number that I can take to Azone, Checker, Napa, CarQuest, etc? Its for a TPI application. Thanks
    Harley
  2. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    I got one a few weeks ago from pick your part from a 90 something chysler mini van this one is a four wire, some are three wire. I'm going to try this one out first before I buy a new.
  3. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    What's the purpose of a heated O2 sensor? What is it??
    Thanks,
    Eric M.
  4. dyeager535
    26,979
    I believe you'll find the recommended part number over on thirdgen.org, and I'm 99% sure that it's going to be delco.
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    It is for EFI applications that can't have an o2 sensor close enough to the exhaust manifold to get accurate readings. For instance trucks with headers. THe o2 sensor gets put into the collector but at that point in the exhaust system the collector is not hot enough and won't give accurate readings because the sensor is not hot enough.
    The heated o2 is connected to a battery source to heat it up and get more accurate readings.
    Harley
  6. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Cool, thanks - never knew that.
    Eric M.
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Got mine from turbo city!:grin:
  8. Snyiper
    Snyiper Registered Member
    Feb 16, 2005
    8
    Southern Maryland
    I believe the Delco heated one is off the corvette!! I know that the heated vette units fit the LS1. They are heated to keep from having to clean them all the time when running headers and the mixture is a bit off.
    Glenn
  9. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Harley,
    I have a 4-wire heated O2 sitting in the garage hopefully going on the truck today (after the girlfriend gets her ride to the doctor) I searched an O2 by application an the one I have is for a 1997 Vortec 350. Then I went to GM and bought teh bactory pigtail harness so I could have a factory weather-pak plug. Then Wade hooked me up with the wiring diagram. It's pretty simple: 2 grounds, a 12V+ ignition and the sender wire to the ECM.
    Chris
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Alll OBD II and newer have them. Now new cars have to have Air fuel sensors, which heat up even FASTER then HO2S.
  11. blazerguy 90
    blazerguy 90 1/2 ton status
    Nov 12, 2004
    126
    EL Sobrante, CA
    Try here, OxygenSensors.com , I ordered a 3 wire oxygen sensor for my 90 K5, it was $45.00 dollars plus shipping.
