Heater/AC control help please
Discussion in 'Pacific Region' started by shane74, Jul 28, 2003.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I did a search but didn't find much. My heater/AC controls don't work right. I tried to trouble shoot it last night, but no matter what I do, the air only blows out the bottom "heater" vent. I did find a small vaccum line (approx. 1/8" dia.) that runs through the firewall into the engine compartment, but then it is not hooked up to anything. I tried plugging it, but that didn't work. I connected it to the vaccum ball onthe firewall, and that didn't work either. Is it supposed to be connected to the carburator or a vaccum tree off the intake manifold or soemthing along those lines? I tried looking it up in my crappy Haynes manual, but the section it refered me to was a blank page! /forums/images/graemlins/angryfire.gif Also, there were no vaccum line diagrams or ANY useful pictures /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif I would appreciate any help I can get on this.
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Is this for your '74? Should be all mechanical cables I thought? Vacuum switches were not used until the mid 80's or something like that...
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i don't think that has anything to do with the heater my 77 is all cable actuated /forums/images/graemlins/shocked.gif i bet one of the cables came unhooked /forums/images/graemlins/eek.gif
  4. reedmit
    reedmit 1/2 ton status
    Feb 22, 2002
    207
    Oregon, Mount Angel
    Did you check the vent tubes? They could have came off or got kinked some how.
  5. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    I wish it was all mechanical. The only thing mechanical is the temperature. That is operated with a cable. The vent selector is a combination of elec./and vaccum.
  6. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Vent tubes? You mean the little lines that run to the diaphrams inside the cab? There is one at the bottom of the heater box, and one on the passenger side at the vent on the floor. Is there another one I am missing?
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    PM HarryH3, he has the diagram I think.
    The following is how my '79 was set up. Though all the controls are cable controlled, the diaphragms are vacuum controlled, via the little 1/8" supply line you found all alone. It is supposed to be fed off the vacuum canister (mounted on the passenger side of the vehicle) which is fed by the motor. I had problems with mine, think my issue was the control itself, which has a port on the back of it (see if you can either see it from under the dash - otherwise you can pull the bezel and check it by pulling it out - held in by a couple of screws IIRC). Maybe the connector (rubber) gets old and leaks vacuum...........dunno. All I know is I never solved it.
  8. reedmit
    Feb 22, 2002
    207
    Oregon, Mount Angel
    I don't know what yours has. I was messing with some wires on my 72 a while ago and in doing so I pulled the tubes off and didn't notice until my defroster wasn't working. Your post just reminded me of that so I thought I would ask.
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    shane, pm me....My 75 has all that stock vacuum crap and i had to fix it all, i know what your going thru /forums/images/graemlins/thumb.gif
  10. BurbinOR
    5,829
    Oregon
    Might want to post it here for the whole group to see the fix..........I could never get mine quite right. /forums/images/graemlins/tongue.gif
  11. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    its the vacuumtube, i can help when I get back from seattle and dont have to use this stupid laptop....I had the sa
    /forums/images/graemlins/deal.gifme prob....
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Shane, here is the correct way for everything to be hooked up. Every hole needs to be plugged in and have no pin holes or the whole system will not work properly. Need any other help, just let me know /forums/images/graemlins/thumb.gif
  13. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Ok, spill it! How do I fix it?? I am frustrated to no end here! I am going to hook my AC back up, but I want everything to work right first.
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Its supposed to be plugging into the vacuum tree that is in between the dist and carb.
  15. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Man that ROCKS! That is EXACTLY what I have been looking for! SWEET /forums/images/graemlins/deal.gif!! Thanks man! /forums/images/graemlins/pimp1.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  16. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Not a problem /forums/images/graemlins/thumb.gif
    You'll be getting a bill for my services in the mail here shortly /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  17. kennyw
    Jun 9, 2002
    13,224
    94
    Oh no, unemployment has turned him to internet prostitution /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif
  18. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    It's a dirty job, but someone has to do it /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  19. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    You'll be getting a bill for my oral services in the mail here shortly
    /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif You never told me you were a "PROFESSIONAL"!!
