heater controls on a 78
Discussion in 'The Garage' started by muddhawg, Sep 22, 2003.
  1. muddhawg
    muddhawg Registered Member
    Jun 4, 2003
    19
    Tennesee
    I am lost on this one, bought my truck in July, the guy I bought it from said that fan only ran on low speed, so I thought okay, blower motors gone. Went out to test it last week with temps. starting to come down and found that motor is working in all 3 speeds, but when hooked up it runs constantly in low!! I checked the speed switch, but the power wire runs from hot side to switch to blower motor factory wiring, with no breaks in between except at resistor, and it seems fine. The temp selecter switchs are mechanical and have no electrical run to them, how do I turn fan off, with out having to pop the hood and unplug blower motor each time? I have never had this problem before. /forums/images/graemlins/confused.gif
  2. Grim-Reaper
    7,385
    Atlanta
    Blower fans in GM's always run on low when the key is on even when it's off. Works as intended.
    I suspect the reason is to keep the box from overheating because the heater core always is in the loop. The low and med settings are run through the resistor pack in the blower box under the hood. all is controled by that big relay on the side of the box. High is straight 12v and on a seperate feed from the distribution block on the fire wall to the left of the Brake booster.
  3. muddhawg
    Jun 4, 2003
    19
    Tennesee
    Cool, then I have nothing to worry about.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep, its super-low /forums/images/graemlins/laugh.gif
    happy heating /forums/images/graemlins/laugh.gif
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you want it off just pull the fuse in the fuse box thats what i do then during the winter months i put it back in /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. muddhawg
    Jun 4, 2003
    19
    Tennesee
    oh crap, another mudhog /forums/images/graemlins/shocked.gif, and I thought I was the only one. /forums/images/graemlins/rotfl.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    nope your not the only one /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
