Heater Core Box Removal?? Need help ASAP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JohnnyFresno, Oct 18, 2002.
  1. JohnnyFresno
    JohnnyFresno 1/2 ton status
    Mar 24, 2002
    194
    Clovis, CA
    How do I remove the heater core box from inside, it has 3 flat top screw type thingies I cant get undone. I removed the 1 bolt on the right side but the box wont budge. It says they are mounting screws ANy helps would be greatly appreciated. Thanks running out of light to work with here /forums/images/graemlins/tongue.gif
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
  3. Grim-Reaper
    7,385
    Atlanta
    Beat me to it! /forums/images/graemlins/thumb.gif
  4. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    yeah the combination of that great article and the haynes manual make it a quite easy job..
    sure is a pain since you have to do a little in the cab, do a little in the engine bay and back and forth...
    but its worth it to get rid of that fishy smell in the cab...
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    They're studs. The nut is on the outside.
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Take very carful look, there's a combination of studs with nuts, and bolts. Some you'll need to remove from the outside (engine compartment), and some from the inside. There's quite a few of them, so look carfully. There's also a nice hidden one thats difficult to remove underneath the blower box, outboard on the lower side on the outside of the firewall, in the engine compartment. Its almost in the fender...the article mentioned above covers it though...
    BlazerMan
