Heater core bypass
Discussion in 'The Garage' started by hi pinion, Jan 8, 2005.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Theoreticly, can a guy bypass a heater core, and loop the lines, together, while awating parts for the heater core install? Or would that hurt anything? Someone told me to just loop the lines, until my new heater core parts get in.Thanks guys , jake:)
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, do it all the time here in the SUMMER.
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    they are different sizes so that might interfer.
    i had my core wired up under the hood when swaping over to non ac
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    oh, i forgot about that.
    seems to me i streched the little hose over the big fitting, then just cut that little bit off once i hooked it back up.
  5. hi pinion
    Sep 25, 2003
    5,354
    Thanks guys, i have an array of copper fittings to loop the 2, so that wont be a problem, later jake:)
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep no big deal, or install water pipe plug fittings in intake and waterpump
    or maybe you have port on radiator tank instead of on water pump
    hmm
  7. hi pinion
    Sep 25, 2003
    5,354
    It was just a general question about bypassing the heater core (cough) (furd) cough....:grin:
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    :rotfl: Still working on it huh....
    So now you are doubting my advise? :mad: :p: Napa sells a fitting that can go from one size hose to the other. I have a coupling do bobber mating the 1/2" inlet to the 3/4" outlet on the heater core. For some reason if I plumb in my heater core my engine overheats. :confused:
  9. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Have you checked to make sure the heater core is not plugged/clogged?
  10. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Someone correct me if I'm wrong here but a heater core is basically a second, albeit much smaller, radiator that vents into the passenger compartment. If your truck overheats with the heater core plumbed in, it's almost certainly plugged or obstructing flow of coolant somehow.
  11. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    That sounds logical to me. And yes you're right about the "mini radiator" theory.
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes it is basically a second rad, but you CAN have a plugged heat core and NOT have your engine overheat
  13. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Nope, it's clear and clean. It is probably not worth discussing because I made numerous threads about it months ago when I was trying to get it to not overheat. No one could figure it out pretty much because actually it doesn't overheat....it screws up the flow of the coolant somehow because the guage will jump up to 260 in about 3 minutes, shut the engine down, start it up 30 seconds later and it reads 170 again. It is like the coolant flow stops for some reason as the pressure builds in the cooling system, but when the engine shuts down it releases the pressure and the coolant can flow freely until the pressure builds back up after a minute or so of the engine running again. I originally thought the air from the heater core was being pushed into the engine as it fills with coolant so I primed the heater core first one time, didn't make one bit of difference. That is the best I have come up with.
  14. hi pinion
    Sep 25, 2003
    5,354
    Excuse me Bobby, but, this isnt about you, and YOUR truck overheating, its my thread, and my heater core bypass thread, NOT yours, so butt out.What do you think this is anyway? A public forum? :D j/k , later,:grin: jacob
  15. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I'll mow over your topic whenever I feel the need, punk. :D SO did you get the lines plumbed together? Pinhead. :D :p:
  16. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    diggin through the thread graveyard
    If you complety disconect the heater core and block off the intake hose from the radiator it will be fine. Won't overheat.
  17. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Um, yeah. It's been that way for 2 years. :whistle:
