heater core probs. little bolts giving me heck
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82Jimmy, May 13, 2002.
  1. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    they are like clips or some crap i can't get them out.
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Ddi you loosen all of them? There are like 3 nuts on the fireewall and maybe 3 bolts, and then a few from the inside. Did you disconnect the hoses from the firewall? Mine were glued on, and i had to yank that thing as hard as I could to get the hoses to pull through the firewall. Also, the stud things could have some of that putty on them which is making them stick. Just force it! It'll come out.
  3. 82Jimmy
    Jun 9, 2000
    702
    Well man, I tried everything, I nearly got out a cutting torch /forums/images/icons/frown.gif
    Anyhow, I took the black stuff off the fire wall on the other side, went under it tried to pry. They are like clips or something, I looped my awesome hose back in with a connector hehe.
    I am still not sure what to do, I don't need a heater right now, but hey, i still gotta have one 8)
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Read Grim's article in the tech section carefully. The clips are on the heads of the bolts that hold the housing in place on the inside and they extend through the fire wall into the engine compartment. If you don't know where to look, they are easy to miss. The one that is under the A/C unit is almost impossible to see.
