heater core question
Discussion in 'The Garage' started by Big GMC truck, May 5, 2006.
  1. Big GMC truck
    Big GMC truck Registered Member
    Aug 23, 2005
    73
    California
    1984 gmc k1500 305
    I needed to replace my heater core. So I took out my glovebox and discovered this black box. I'm assuming the heater core resides in the big black box. My question is how do I unbolt the box from the firewall. Inside the cab, I see these circular bolt looking fasteners that hold the box to the firewall. How do I unscrew them? Thanks
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    IIRC the front of the heater distribution box (the big black box that covers the heater core) has round headed bolts in front with hollow nuts in the engine bay side. Unbolt it from the bay. I removed the inner fender to get at them easily IIRC - been a long time since I changed out the heater core.
    I took pics as I removed stuff, so I wouldn't mess it up[ gettting it all back together.
  3. Big GMC truck
    Aug 23, 2005
    73
    California
    To get to the nuts, do I have to take the blower motor assembly off?
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    As mentioned, you may have to remove the wheel well / inner fender piece to get to one of the nuts, it's tucked down in a hard to reach area,,,
    that just didn't sound right.:doah:
  5. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    no you dont have to
    jut start taking screws out inside the cab youll figure it out, its not that bad
  6. Skigirl
    Apr 2, 2001
    2,563
    Like R77 said, no you don't need to remove the blower motor. You will need to unhook the vac line stuff and I think there's a connector of some sort to one of the doors inside the housing, on top of the distribution box. I took pics along the way so I wouldn't forget where everything went and its position when I removed it.
    You get some spillage when you remove the core. Make sure any carpeting is moved out of the way and you have some towels or something there to sop stuff up.
  7. 4xcrazy
    Oct 31, 2003
    9,472
    5
    i didn't say anything about the blower motor assembly, i said you had to remove the inner fender well to get to one or two nuts that are located to far down in a cramped space to get a wrench or anything in there,,,remove them from the inside???? they are flat round surfaces, nothing to grab on to????
    then you can remove the heater box and flapper unit thingy, being careful of the vacuum hoses and little plastic clip that connects to the flap door.
  8. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    As mentioned you have to pull the inner fender only so you can get to one single nut that holding on the air box thats under the dash. The rest of the nuts are easy to get to, its only that one thats buried in between the firewall and fender. Once you get the box out the rest is easy as far as putting the new core in. This might help a little bit...http://coloradok5.com/heatercore.shtml
