heater core removal
Discussion in 'The Garage' started by dheavychevy38, Nov 21, 2004.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    anyone have any tips for removeing it on a 89 k5
  2. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I had one leaking on a '86 Blazer and on it you have to remove the dash pad to get to it. It was winter and I haven't a garage so I took it to a Auto Shop to have it done. It's alot more difficult than the older models.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nonsense, it's not that hard at all.
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Maybe I was misinformed. Please let me know if I was! /forums/images/graemlins/dunno.gif /forums/images/graemlins/confused.gif
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I changed mine out on my 85' for the first time with the help of the CK5 write up. And I am a novice mechanic. It was pretty easy, one tip, if you have a digital camera take pic's of how the linkage is hooked up. I did not and it took me a while to figure it out /forums/images/graemlins/rolleyes.gif
  7. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Its been a while since I changed mine on the 88, but Ill try to explain it. It was fairly easy. Dont think I removed the dash pad, but it might make it a little easier. I think the glovebox needs to come out too. The cable from the heater control needs to be removed, along with the 2 hoses from the firewall in the engine bay. A few vent tubes might need to be disconnected too. Then, there are like 3 or 4 nuts that hold the heater box onto the firewall. You get to them from the engine bay also. Might be a few inside the cabin too. When the heater box comes out, you should be able to see how the heater core comes out of the box. Its not too labor intensive, might take 2 hours total. Pretty cheap too, new cores are usually less than $30.
  8. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah its not hard at all i JUST did mine in 20 minutes
    there are nuts on the moter side of the firewall, pull the hoses and put them up high, pull the glove box out the box will come off under the dash, two 1/4" or 9/32" hex screws and the core comes right out, thats it!
