heater core removal
Discussion in 'The Garage' started by GONZO2, Oct 3, 2003.
  1. GONZO2
    GONZO2 1/2 ton status
    Jul 17, 2001
    137
    formerly Great Falls, MT now Lompoc, Ca
    alright looks like the heater core on the old blazer is leaking, so how does this thing come out? i looked under the dash (my 79 ta came from there) and looks like the duct housing has some type of wierd screw head that is smooth all the way around and it's too flush to wall to grab with anything. does it come out from under the hood? i can see where the supply and return hoses, but unless you remove the entire ac/ fan motor housing i can't see how it would come that way /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
    i don't have a shop manual for it, so if anyone does /forums/images/graemlins/1zhelp.gif
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I took out the glove box and went at it from the inside, drilled out the factory bolts and used larger sheet metal screws....
  3. 77Jimmy
    77Jimmy 1/2 ton status
    Sep 3, 2002
    661
    Atlanta, GA
    This might help... /forums/images/graemlins/grin.gif
    click here
  4. GONZO2
    Jul 17, 2001
    137
    77jimmy
    thanks for the link. /forums/images/graemlins/thumb.gif
    if i read that right you loosen the bolts around the ac/ blower motor housing, but do not remove the housing. this should free the box under the dash on my 88 /forums/images/graemlins/k5.gif .
  5. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Grim's article is the best I have found, far better than Chiltons or Haynes. The only thing I did different, and I may have just been lucky, before attempting to remove the inner fenderwell to get to the bottom bolt, I used two long extensions and a universal joint and a extra set of hands and was able to remove the bottom bolt. Otherwise I followed Grim's instructions and didn't have any troubles.
  6. johnnieg
    johnnieg 1/2 ton status
    Nov 10, 2002
    130
    CSU, Ft. Collins, CO
    i just replaced the heater core in my 88 about 2 months ago and it was very time consuming, but possible.
