Heater core replacement... how long to plan for???
Discussion in 'The Garage' started by foxman, Jan 27, 2004.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    Fogging up windows, antifreeze on the passanger floor, and smelling like a candy factory... /forums/images/graemlins/doah.gif I can't believe it waited for the coldest, crappiest part of the year to happen, but there's no denying it, so I've got to get out there and do it.
    My Question is how long should I plan to be out there?
    Any tricks or tips that ya'll might share with me that would help out? /forums/images/graemlins/peace.gif
    Thanks a mill.
    Jeremy
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Try this /forums/images/graemlins/waytogo.gif
  3. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    you might want to do a quick pressure test on your new on,
    just plug one inlet and put a piece of hose on the other, set it in a sink filled with water, and slightly blow air
    into the hose to see if you can see air bubbles, last time
    i replaced my heater core i had to return 5 of them until
    i got one that didnt leak, there made in taiwan and i think
    they get bumbed around during shipping or they dont know
    how to solder, but it was a pain in the arse, /forums/images/graemlins/angryfire.gif
  4. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    It really helps if you have a helper, when you stab the heater box back in (Then their will not be any of those 4 letter words, and thaughts of trading your "baby" off!). I'd plan on at least 3-4 hours. Good luck!!!
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Mine has taken 18 months, good thing I live close to work /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  6. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Maybe I was really lucky but it took me right at an hour from start to finish. Course I was hustlin cuz on account it was my "lunch hour" and my boss back then was a serious dick. His name is even Richard. Anyways, the hardest part is the nuts under the AC box. The rest is a piece of cake. A little bit of advice, really pay attention when ya pull it apart makes it a heck of a lot easier to put back together. Good luck.
    Allan
  7. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    It really isn't as bad a job as I thought it would be. Grim's write up is good. I found that removing the nuts on the engine compartment side was easier with a deep 1/4 drive socket, a flex extension and a cordless drill. Especially the lower nut.
  8. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Thanks for the post, I am in the same boat. I am doing mine on sunday hopefully /forums/images/graemlins/thumb.gif
  9. steedalx
    steedalx 1/2 ton status
    Dec 19, 2003
    142
    Chattanooga, TN
    Mine took around 3 to 4 hours. The only hard part was the hour I spent trying to get the bottom left nut off that sits between the blower motor and the inner fender. I eventually used a big pry bar and bent my inner fender down enough to get a swivel socket down there. I also pulled my A/C off so it was a bit easier with the evaparator removed...good luck
  10. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    I had never done it before, and it took me just a little over 3 hours with Grim's write up. Good luck /forums/images/graemlins/waytogo.gif
  11. jwduke
    Aug 25, 2001
    721
    Put some electrical tape on that nut, put the socket on that nut you can't see, and it goes on with ease!
