Heater Core
Discussion in 'The Garage' started by 82_k5, Nov 6, 2005.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    I have a 92 suburban with a very leaky heater core. I am having a heck of a time getting the ducts taken apart to get to the core. I tried taking the upper half off but it is impossible to reach some of the bolts, i have no idea what to do now. Chiltons is useless. Any tips would be greatly appreciated.
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I think there might be some nuts or bolts only accessable through the engine compartment. I dont have the newer style interior, but hopefully they are similar enough.
    I had to pull the dash pad off, then take out a few of the ducts around the heater box. There was one bolt holding it together I think, the rest were just pressure fit. Some were held together with duct tape. Then pulled the box out. Heater core is inside.
    Sorry I cant help more, but thats what I did. Wasnt too hard.
  3. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i believe their are 3 or 4 bolts assesable from the engine compartment only, you need to remove the inner wheelwell (if not already removed) than it is pritty much pressure fit and a think 5 more under the dash!
    LUKE
  4. caleb22
    caleb22 1/2 ton status
    Apr 15, 2005
    193
    SC
    I just did my 89 two weeks ago. I actually took off the entire fender and inner wheelwell but you can do it by just removing the inner. There are some bolts that attach to the heater box on the inside and stick out the firewall with nuts attached. These will be at the bottom. I removed the dash pad and glovebox too. I actually went ahead and removed all the ducts, replaced the dash speakers, cleaned it all up, and put in a new cheap CD player.
    Once you get the box out I had to undo a lot of screws inside the box and some of the lever doors to get the core out.
    Do you best not to break the seal on the firewall side of the heater box.
