heater ellimination
Discussion in 'The Garage' started by d coenen, Feb 18, 2005.
  1. d coenen
    d coenen Registered Member
    Jan 21, 2005
    76
    bonesteel s.d.
    if i remove all my heater parts could i put inthose little heaters you plug into the cig lighter from wal mart ? like mount them each of the de frost and a couple under the dash for your feet . if you could is there away to wire them to gether and just use a switch. reason is mine is totally gutted due to a fire. and how much heat due they really put out? thanks
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i dont know about the cig heaters, but have you looked into a mojave heater?
  3. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    doubt cig lighter heaters will do much for ya. I think they are more for supplemental heat than anything else. On a 50 degree day they would prolly be fine... but if its 35 and you have frost on the windshield, it aint gonna cut it.
    I recently got a mojave style heater from summit. It cost $159.99. It supposedly can put out up to 28000 BTUs. I got the dual vent style. Im gonna run up a hose for defrosting capability when/if I ever need it but other than that it looks like a sweet little heater. Its small, made of metal (no lame plastic crap here!), it comes with a nice 4-position switch, mounting brackets, all the wiring you need and clear directions too. The intake hot water hose inlets are also the same size as the stock ones on my K5. I'll post some pics when I get done with the install.
    j
