Heater fan relay
Discussion in 'The Garage' started by TrcksR4ME, Aug 5, 2004.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    The fan for my heater has quit working, zip nada nothing. I can hear a little click coming from under the hood when I toggle the switch from lo to hi, I assume that is the relay? Looking under the hood I see a relay looking thing attached near the fan with some plugs going into it, would this be the relay? Also where would one get a replacement, is this something Shucks or Napa carries? I would like to replace it before going camping this weekend in case I need to use the heater/defroster or use it to help cool the truck if need be. Thanks! /forums/images/graemlins/thumb.gif
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Yup, that is the relay, most everyone carries them and cheap too. Does your fan wok on other speeds? Most of the time when the relay burns out you just loose the high position. It might be time to replace the whole motor, they seem to be going out a lot recently, selling them quick around here.
    Krennen /forums/images/graemlins/thumb.gif
  3. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Turned out that the blower motor had gone out. I didn't figure it out until splicing a "2nd design" relay from a van into my setup. Turns out the blower from an 84 van fits in a 77 Blazer /forums/images/graemlins/thumb.gif /forums/images/graemlins/whistling.gif
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can directly wire the blower motor too. This is what I am doing on my K5. I took the AC box out and only have the blower motor left. I am going to build a plate to the heater core so I get heat and the blower motor is getting wired to an aux. fuse panel I installed. It will only have hi speed but it will blow lots of air when I flip the toggle.
    Harley
