heater fan sqweel
Discussion in 'The Garage' started by TC4x4, Nov 21, 2006.
  1. TC4x4
    TC4x4 1/2 ton status
    Sep 12, 2006
    831
    Michigan
    i was driving around a parkinglot waiting for my friend and saw a huge drain area where i could test out the ole articulation and i slowly drove into it with my front right wheel and as soon as it dropped my fan swarted howling really loud ina high picted noise now when its on it howles really loud any ideas on what i should do about this or what caused it to happen thanks
  2. my88texastruck
    my88texastruck Registered Member
    Oct 9, 2006
    37
    Northern Michigan
    You can replace it quite easily as it is accessible from under the hood - they are available at most auto parts stores. What caused it to happen? - the bushings in them wear out causing the squeel.
  3. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    There's a small hole in the end of the motor, a drop or two of oil in there will get more life out of it. But yea its very easy to change out.
  4. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    I just bought one for my sub for like 12$.
  5. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    lube er up!.
    I've drilled a small hole in the end cap of the motor where the bushing is under the hood,and used a oil can to squirt some motor oil onto the bushing..this works for a awhile,then the motor will squeal again sooner or later..I got 16 years out of my howling heater blower motor in my 74 K20--just had to add a few drops of oil every fall--I never bothered to change it--it still worked!--if it aint broke I dont fix it!..:crazy:
