HEATER HELP!!! asap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Oct 9, 2001.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    ok well last winter my heater worked fine, well the 1st time it was cold in the morning i went to turn on my heater, and NOTHING comes out, not the ac, not the heat, not the defrost, not the heat, NOTHING so then i tried it that afternoon to test it and it worked. some thing happend all last week, so needless to say its been a cold ride to school. so any ideas on what is happening? how would i fix it?
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    If the heater core is bad, look for a write up on how to swap it by Grimmy on the tech sections on the home page.
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    You just don't got heat? Look behind yer glove box for the two levers...see if you can move them yourself and get some heat. If not...read Grimmy's article and change yer heater core...also make sure that you still have the heater core hooked up....seen that before....
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    If it wasn't for bad luck I would have no luck at all!!
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Well if we're talking no fan movement then there are lots of things it could be. First of course is try another motor. Then on the side of your heater box next to the motor is a relay to kick in the fan. You can pop the cover off and try to turn on the fan and you should be able to see it close. There is the switch for your fan in the dash, the one for speed, and the main switch which turns it on and selects heat, a/c, etc. There is also a blower resistor under your dash, not sure about that but I know its there. There is also a fuse and obviously check for good connections.
    Usually if its intermittent on and off then its time for a new blower motor.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  5. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Its your blower motor. Mine did that, replaced it and problem solved.
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  6. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    My blower motor went out also if it was your heater core you would mosti likely be able to smell it and see it. cehvk your ground for the blower motor I know my connection was looses and tightened it and it works just fine.
    1985 GMC JIMMY
