Heater hose rerouting...
Discussion in 'The Garage' started by ryoken, Apr 27, 2006.
  1. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    Ok, fellas, help me out here... I'm probably just having a brainfart here and not thinking this one all the way thru....
    I'm about to ditch my stock radiator in my 87 TBI K5... I'm going aluminum and looking at the economy universal from Summit...
    http://store.summitracing.com/partd...4294839040+400304+4294810996+115&autoview=sku
    I've read on here they're decent, and construction sounds good..
    I've decided to go without plumbing my trans cooler thru and leave it just thru the cooler out front... Takes a little to get it up to temp in the winter, but I dig the 180 temps in the summer.. Plus I like the simplicity of the plumbing and its done that way already...
    My question is, whats the deal with the one heater hose to the rad? Never seen that in any of my vehicles... I will need to eliminate that if I go with the Summit rad.. Can I just plumb that line to the blocked off pipe plug on top of my water pump? The other one is the one to the back of the intake, per the normal TBI setup..
    Pretty certain the one running to the rad is the return from the heater core, with the intake one feeding it.. What is the flow direction at that plug on the pump? Can I use that as a return, or is it pressure?
    here's a quickie pic, figures it would be smudged right where the plug is.... Guess I should fix that leaky waterneck while I'm in there too... :doah: :haha:
  2. jaros44
    jaros44 1/2 ton status
    Jul 12, 2005
    408
    Outside Phila. Pa.
    the top hose of my heater core goes to the intake mani. the bottom hose goes to the left side fo the water pump or top where ever your plug is. So flow would start at the top of the rad go to the top of the engine and out either at the water pump or as you state out the lower hose of the heater core.
    Called the electric water pump manu. and since I don't have any heater hose hookups on my pump. he said to buy an adapter that tees off the bottom rad hose for my heater hose hookup, so I guess it is the same with you.
    As long as the lower hose on your heater hose goes to the bottom of rad. you will be ok
    How was Englishtowne? Later J.
  3. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    My big block uses those 2 ports on the water pump for the heater core. This is the way it was when it came out of the 77 2wd truck so thats the way I hooked it back up. Good thing too, because my rad doesn't have a spot for the heater core hose.
  4. dyeager535
    26,975
    On my water pump that's an "in" port, (same location) I'd bet yours is too.
  5. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    5/8 to intake and 3/4" to waterpump
    some have the 3/4 going to the radiator tank, and the waterpump plugged off with pipe plug
    5/8" always went to intake either way
    its real simple :D
  6. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    yeah, i figured it'd be fine.. I'm just used to pre-tbi, front of intake (where they have the TPS) and water pump for my connections...
    thanks guys....
