Heater hose routing HELP its cold here and i need heat
Discussion in 'The Garage' started by khotmer, Oct 30, 2002.
  1. khotmer
    khotmer 1/2 ton status
    Oct 23, 2002
    228
    columbus, oh
    Re: Heater hose routing? Where should they go? [re: Goose]
    10/29/02 07:40 AM Edit Reply
    what do you guys think about going from the water pump to core and from rad to core?
    the previous owner didnt connect it (i am guessing a bad core) but he has the temp line going to the intake and i really dont want to move it to the other side of intake if i dont have to.....
    Honey, It's not for me its for the kids..... grin
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    OK, it's 26 degrees and snowing lightly, but I went out and looked under the hood of 2 of my trucks for ya. /forums/images/graemlins/thumb.gif My '75 has a TPI setup, but it has the heater connected to the intake and the water pump. My '91 S-Jimmy has the heater connected to the intake and the radiator. I'm pretty sure that my wife's '94 Suburban is setup the same as the '91 S-Jimmy, as I put a new water pump on it recently and it didn't have a heater hose going to the water pump. My '75 has a (blocked off) heater hose connector on the radiator, so it was probably hooked there before the TPI engine swap.
    What thermostat are you running? A 160 won't make much heat at all in really cold weather. A 195 is MUCH better for keeping your toes toasty! /forums/images/graemlins/cool.gif
  3. khotmer
    Oct 23, 2002
    228
    columbus, oh
    Thank you for looking....Not sure what the themostat is but i have it hooked up from the water pump to th coor and then to the rad....should i move it to the intake?????
  4. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    mine is the same way /forums/images/graemlins/thumb.gif my heat works well
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I think I'd go the easy route first and drop a 195 degree thermostat in there. /forums/images/graemlins/cool.gif
