Heater output on my 87 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlackK5, Mar 21, 2002.
  1. BlackK5
    BlackK5 Registered Member
    36
    Wyoming
    I have an 87 K5. 350 c.u. I have never been impressed with the heater output. Just doesnt seem to warm up the cab very well. Do the heaters in these things just suck, or is my heater core's number up!
  2. radar
    radar Registered Member
    Oct 28, 2001
    26
    I have a 86 K5 and my heat kicks ass!!!
    When is the last time you flushed out your heating system?
    Also what tempeture thermostat do you have?
  3. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Before you shell out cash to get a new heater core, flush it. It will only take about 10 min.'s and should help out a ton. Flush and backflush the core till you get clear water. Saved me some cash on my 89. Made a HUGE defference too.
  4. dyeager535
    26,980
    AC or not, HD heating option or not? There IS a difference. Stock Non AC heaters suck.
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    try backflushing like others have said... otherwise check the engine temp/thermostat. If that fails it is most likely the core and they aren't the easiest to replace.
  6. BlackK5
    36
    Wyoming
    Flushed just this past fall. I have a 210 degrees thermostat in it ( I am assuming...since that is what the temp gauge reads when engine is warmed up).
  7. possum
    possum Registered Member
    Jan 9, 2002
    72
    NC
    maybe sound like a silly question... but how do you flush out the heating system?
  8. possum
    Jan 9, 2002
    72
    NC
    may sound like a silly question... but how do you flush out the heating system?
  9. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Check all your heating vents for proper operation.
    Also check your heater hose vacuum actuater valve is working properly. This is supposed to close when you turn on the A/C.
    Good luck
