Heater Problem--No Heat
Discussion in 'The Garage' started by mtnman210, Jan 14, 2007.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    the heater in the blazer was wokring fine and all of a sudden I only am getting cold air. The blower works, it's pumping air, it's just COLD. Also with the heat/air controls on off if I move the switch to hot it takes a long time to get any warm air in, If it gets any. I don't know if it's realted, because I think I'm just out of freon, but the AC isn't blowing as cold as it should. But like I said I think I'm out of freon.
    I've check fuses, and all the connections on the heater and can't find anything. What could cause the blower to still be fine but I'm not getting any heat out of it?
  2. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    is there antifreeze in your radiator? the truck uses this to heat the cab. check for leaks around the heater box or on the radiator
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It sounds like there's a problem with your main heat mixer door, which is vac-operated. Trace your vac lines and see if something's been disconnected.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    First make sure that the heater box trap doors are working correctly, if that is ok then check fluid level in the cooling system. If cooling system level is fine then i would suspect a plugged heater core.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    or a bad heater control valve, the valve inline with the water that controls the amount of water getting to the heater core...
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I've never seen a heater control valve on a gas powered Chevy ever. Fords used them alot and i've had Fords with them but never seen one on a Chevy.
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Then how do you expect the temperature to be adjusted from cold, to luke warm, to warmer to hot,,,,this valve is on EVERY SINGLE 80's model Chevy i have ever owned. It is operated either by a cable lever, or a vacuum switch through the control panel on the dash (temp selector)
    It adjust how much hot water flows through the heater core,,,,
    this pic is the one on my 89 Suburban, this is not the stock one,,,the stock one had 4 ports to accomodate the rear heater as well.
    I do believe however there is a new version, mid to late 90's on up, controlled electronically through the dash controls.
  8. Can Can
    15,552
    136
    Funny, that valve has been on NONE of the mid-80s trucks I've owned.
    Is it maybe only found on non-AC trucks?
  9. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    yeah Ive never seen one either. Ive owned 3 and worked on at least 5 others and none of them had one.
  10. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    That is definately a heater control valve, but not on my factory 1989 blazer, nor my old 1976 blazer, nor on my buddies 1988 blazer, shall i keep going?
  11. 4xcrazy
    Oct 31, 2003
    9,471
    5
    so you guys just run with heat all the time then huh,,,or do you expect the "blend doors" to adjust the heat with some cold air from outside,,,,hmmm, weird, oh well, again, i don't know sh!t here, just babbling on about things that were NEVER on a Chevy..
    Have fun
    EDIT : this was worded weird, sorry :doah: :crazy: :o
  12. 4xcrazy
    Oct 31, 2003
    9,471
    5
    better yet. maybe it's just an Arizona thing,,,hmmm, i dunno:crazy:
  13. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    For the record, i did not say they were NEVER on a Chevy but rather I'VE never seen them on a Chevy. My blazer is bone stock as far as the A/C-heat is concerned and my 1989 blazer NEVER came with a heater control valve inline with the heater hose as you've pictured. My heater hose goes from the intake manifold to the heater core directly and the other hose goes from the heater core to the radiator directly with nothing inline with either hose.
  14. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Sorry, don't get me wrong, i am just seriously confuzzzed, i keep hearing about people NOT having these valves on their trucks or whatever, I haven't seen them without them, so i am not sure on how a system without the valve, is supposed to work i guess..., i know if i remove mine, and all others in the past i have owned, i get nothing but hot air,,,all the time :confused:
    anyways, we kinda got off the topic originally posted, so anyways,,, :p:
  15. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I'm sure there must be something different about the A/C-heater suit case or trap door configuration between trucks that use the valve and the trucks that don't.
  16. 4xcrazy
    Oct 31, 2003
    9,471
    5
    you know some people are baffled about this, when you receive international phone calls aboot it :doah: :p: :D
    i know i am, :crazy:
  17. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Damn, now we have Paul all riled up. :haha:
  18. Can Can
    15,552
    136
    Okay, TJ. As promised, here are the pics of my heater hose setup.
    1. Here's a pic of the hoses going into the heater core:
    2. This is one of the heater hoses coming out the manifold:
    3. And here's the other hose coming out of the rad itself:
    You'll notice the lack of a heater control valve anywhere in the system. The heat or lack thereof is controlled by a blend door. FWIW, all three of my trucks has the exact same setup.
  19. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    All of the 80's era trucks I have seen haven't had the valve on them the mixing is accomplished with the doors in the interior duct box. My IFS era rigs all have that valve though. I recently went hunting for some heater boxes and I know that valve wasn't present in the systems at the yard about 20 or so trucks.
  20. 4xcrazy
    Oct 31, 2003
    9,471
    5
    again, i am not sure why this is so weird, i even looked up one at Autozone awhile back, and they carry it, have it in stock listed for my year of truck and all....
    Mine is a factory setup, even has the vacuum hose coming out from the firewall to supply the controlled vacuum to the valve.
    I have taken this out once, and run the hoses directly, and i get nothing but scorching heat, will not cool down...
    again, weird,,,i dunno
