heater problems 85 k5 jimmy
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pike23, Mar 31, 2003.
  1. pike23
    pike23 Newbie
    Mar 31, 2003
    I hope you guys can help. When I cut on the heat, it works fine on fan speeds 1-3. On the high speed for the fan it stops blowing. I have replaced the switch but still have the problem. Any suggestions?
  2. BRN78BLAZER
    BRN78BLAZER 1/2 ton status
    Feb 5, 2003
    133
    Stoney Creek Ontario, Canada
    you need a new blower motor relay. It's mounted on the outside of the evaperator core case near the blower motor. Just folow the cable from your motor, it will come from it. replace it and it should be fine.
    ps its usually a silver coloured box about 2"x1.5"x1" or so and is made of metal and plastic.
    sorry if none of this makes sense, im very tired.
  3. pike23
    pike23 Newbie
    Mar 31, 2003
    Thanks for your help. I'll try it and see how it works. Any idea on cost?
  4. BRN78BLAZER
    Feb 5, 2003
    133
    Hard to say a price, you could try a wrecking yard, most likely you'll find one. They're the same on all the fullsize trucks and most cars from 70's to early 90's with A/C. Take your old one with you and find one that matches. Or if you don't want to do that all I can say is try a dealer or autoparts store.
