Heater problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigd652, Jan 25, 2004.
  1. bigd652
    bigd652 Registered Member
    Jan 22, 2004
    26
    Michigan
    My heater is not switching between vent, floor, etc. I cheaked some of the vacuum hoses and all looks ok. Anyone know where else to look? Could the selector slider switch thing be dead???
    D
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Click on the link below. It should help you fix your problem, brother:
    Heater repair
  3. bigd652
    Jan 22, 2004
    26
    Michigan
    Already read that one...... Anything else?
  4. Can Can
    15,552
    136
    Is your truck equipped with AC?
  5. bigd652
    Jan 22, 2004
    26
    Michigan
    Yes it is. But it doesn't kick the compressor in when I switch it to defrost
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I had one that always blew out of the floor vents. Turned out to be a Bic lighter that had fallen down through a defrost vent and lodged in the door that determines where the air flows. /forums/images/graemlins/blush.gif
  7. bigd652
    Jan 22, 2004
    26
    Michigan
    Yes but are the vac lines prone to leak or is there something else I should be looking at?
