Heater Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by opfor2, Jan 2, 2003.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    When I put my 1990 blazer into the heater mode I get heat coming both from the floor and dash vents. This problen just occured within the last month or so. Before when you put the heater into heat mode it would blow mainly from the floor vent and a little from the window defroster vent. Any ideas as to where I should look to fix this ?
    Thanks in advance
    Dan....
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    There is a little door inside your heater plenum that controls where the heat goes. Your door should be activated by a cable or vacuum. I would start at the switch and track it down from there. This was a "hot" topic a week or so ago. There may be a little tab on you door that is broken. Try a search if you need some more info.
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    if your blazer doesn't have factory A/C, it's quite a simple set-up, a lever on your heater panel moves a cable that moves the flap in the heater box.
    An A/C set-up uses vacuum actuators that move the different flaps in the heater system, they are controlled by a vacuum switch in the heater panel.
