Heater, vents, defroster don't work
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnny reb, Aug 21, 2000.
  1. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    Heater, vents, defroster don\'t work
    My vents, defroster, and heater just stopped working the other day. No warning, just stopped working. I checked the fuses already. Where should I look next?
  2. truyoopr
    truyoopr Registered Member
    Jul 30, 2000
    17
    new jersey
    Re: Heater, vents, defroster don\'t work
    Is your system vaccummed or cable runned. If is is vac then the line might have gotten disconnect from a vacum source. I had this problem before and all i got was the defrost. Found that the line going from the firewall to the carb had gotten disconnected. Hope this helps
    Come and Get Some
  3. johnny reb
    Mar 6, 2000
    326
    Pittsburgh, PA
    I don't know if mine is vacuum or cable. I think I may have an electrical problem. When I turn the vents or defroster on, I can't even hear the motor running. Maybe I have a bad motor?
  4. truyoopr
    Jul 30, 2000
    17
    new jersey
    If it was vaccumed then you would hear a rush of air when you changed it from defrost to vent. You might have a bad blower motor, or it might not be grounded. I had that problem too.
    Come and Get Some
  5. johnny reb
    Mar 6, 2000
    326
    Pittsburgh, PA
    I guess mine is vacuumed then. Even though nothing works, I still hear the rush of air when I switch from AC, to vent, to defrost.
  6. Dave A
    Dave A Registered Member
    Jul 18, 2000
    33
    St. Louis, Missouri
    Check your blower motor. I've had it go out on a couple of my vehicles. If no air is coming out of the vents even when you change the blower speed settings I bet thats what it is. Make sure that its getting power and that its grounded well. If both of these are O.K. replace it, its cheap and easy.
  7. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    If you hear that rush of air then it's your blower motor. Get a manual if you don't have one and do it yourself, it's not that hard to do. Good luck.
    <font color=purple>L8r,
    .Riz.<font color=purple>
  8. johnny reb
    Mar 6, 2000
    326
    Pittsburgh, PA
    Is the blower motor located inside the engine compartment or under the dash somewhere?
  9. truyoopr
    Jul 30, 2000
    17
    new jersey
    The blower motor is located in the engine compartment. i f you were looking at the firewall then it would be on your left toward the top. it should be held in place with six self tapping screw. I got mine from pep boys for 18.99. Good luck.
    Come and Get Some
