Heater won't work
Discussion in 'The Garage' started by fordeater, Feb 12, 2005.
  1. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    Ok, so i got a new blazer on sunday. I dropped a motor in it tuesday and wednesday, got it running good, and now i'm working on the little bugs. One problem is that the heater/blower won't work. I don't know what it is. I checked fuses, all of them seemed ok. I don't know which relay goes to the blower motor, so i can't check that. Anybody have any suggestions? Kinda hard to defrost the windows with no heat.
    Doug
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If you tested it before you put it in I wuld check the ground wire. If not, test it (hook it ddirectly to the batt) and if no blow - they are about $15-$20 IIRC at Autozone.
  3. Storm Trooper
    Nov 24, 2000
    4,640
    Do you have a meter? Check the voltage at the blower. Poor connections will heat up and cause a failure. If you have voltage there, check of contenuity through the motor (complete curcuit). You can pick up a cheap meter almost anywhere.
  4. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    well it the moter still works (3 foot chunk of wire will find out real fast)
    then check the resistors, the heater box on the fire wall has a pulg in it. 3 wires go to it and one goes to the moter, remover the two screws and pull it out.
    (i would recomend spraying something on it first, tends to rust in to the plug)
    if the little coils are rusted and busted then replace it.
    if its fine then pull your dash and bezel and pull the heater controls and make sure the wire is pluged in to the fan switch.
    if it is cut the wire a bit and check for voltage with the key to "ON"
    if it dosent have any you have a cut wire or bad fuse ( please check ALL fuses first or you will be pissed. all of them)
  5. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    yeah, i suppose i should check all fuses. The other day i was trying to fix the radio in the work truck, memory wouldn't work, so i check basic fuses. None were blown. So, about a week later i realized there was no horn, changed out the HORN fuse and the radio worked.
  6. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    ok, i got it blowing now, and the heat works, BUT, i can't change from vent to defrost or anything else. It just stays on vent. I have no clue what this would be. I thought maybe the switch on the a/c control panel, swapped those out, still same thing. Any ideas?
    Doug
  7. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    My '77 k20 had cables, but some of the new ones have those vacuum operated doors. You just said you got a new blazer but you didnt say how new, or a/c nona/c. need more info. Also, I remember readind a post about the little clips attached the vent doors, breaking off, and not opening or closing the doors anymore.
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    My 78 had vacuum, and broken clips.
  9. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    Its an 84 k5 Silverado with a/c. I'm assuming its vacuum, but do i have to take apart everything to check that the doors are opening and closing?
