Heating Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Dec 13, 2000.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Well my Heat works awesome, It's Nice and Hot. The question is it takes about 10 minutes to kick in, I know the engine has to warm up, but is there anything I can do to get the heat working quicker, by the time it kicks in I'm over half way home from work. And I'm not gonna start my engine earlier, too many people I don't trust hanging around my work.
    89 K5 Silverado
    http://mudfrog.coloradok5.com
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    You could try a trick that the truckers use by covering part of your radiator with something to restrict airflow through it.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep. Cover that radiator. You'll be amazed at the difference it makes. I just cover it with a large piece of cardboard. Leave a 6-8 inch hole in the center so the fan isn't sucking against a vacuum. I've never had overheating problems with this setup and the heat comes on WAY faster without all that cold air blasting through the radiator and across the engine.
    http://ThunderTruck.ColoradoK5.com
  4. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I am having similiar problems with my heat. I have brand new heater hoses, heater core, thermostat (195) and a two year old 3 core radiator. It takes forever to heat up. The blower works good also. I also have a piece of cardboard in front of the radiator. I even have it run for 15 minutes every morning. Is there a way to route the entrance to where the air is pulled in by the blower motor to get it near the engine. So, that it is already getting semi-warm air before it blows over the heater core. I can't seem to think of any more ideas. I changed the thermostat twice to eliminate that also.
    Communication Breakdown
    74 Blazer
    Zeppelin
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Zepplin, with a rig as old as yours, I'd bet that the foam seals around the edge of the temp control door are worn out. That would let lots of cold air get mixed in with the heated air. [​IMG]
    Look under the right side of the dash while moving the temp control lever back and forth, to find the part that's moving under there. Then you'll need to take apart the plenum to take a look at what should be happening in there. I'll bet you'll find the door isn't closing tightly enough. Put a new foam seal on there and you should get warmer air in the cab.
  6. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    If your running an electric fan make sure it isn't turning on to early. Also some people run a heated blanket over the radiator to keep it warm longer
    C'moe
    <font color=black>the blazer is "Back in Black"
